Cybia Plugins
otimos plug-in filters em:
nao vi todos ainda…
entao assim que forem testando alguns legais, coloquem os resultados aí…
:smiley:
AlphaWorks
A single Photoshop-compatible plug-in filter for quickly removing black or white values and making the region transparent. There are 6 different options for you to choose from, depending on the type of image you are working on (colour photo, mono photo, lineart). It requires the use of “layers” so remember the effect must be applied to an image that is on a layer above the background in order for it to work.
Download (136.7kb):
ColourWorks
A single Photoshop-compatible plug-in containing 20 effects for modifying image colour values in various ways. You can use them for subtle correction of your digital photos and CG graphics, or experiment with the more dramatic transformations that are available. Although quite basic these filters can be handy for use on a regular basis.
Download (163.6kb):
EdgeWorks
A single Photoshop-compatible plug-in containing 20 effects for creating dramatic edge and colour modifications. They are best used when experimenting with intense photo transformations for a highly stylized look. They are also handy when creating texture effects.
Download (165.1kb):
ScreenWorks
A single Photoshop-compatible plug-in containing 30 individual filters for creating various screen/mesh patterns. It provides you with a quick way to add small detailed and repetitive texture overlay effects to areas of your image in one easy step. The single slider setting gives you the option to add the chosen pattern on top of your image, or make the layer background white.
Download (150.7kb):
EmbossWorks
A single Photoshop-compatible plug-in containing 20 effects for producing various quick and easy embossing styles.
Download (225.4kb):
SwapShop
A single Photoshop-compatible plug-in containing 15 effects for switching the colour values in your images. Useful for experimenting with interesting combinations and creating surreal results.
Download (148.1kb):
MasterBlaster
A single Photoshop-compatible plug-in containing 20 effects for “blasting” intense colour into your images. Ideal for when you need to add dramatic impact to your photos or artwork.
Download (155.4kb):
Mezzy
A single Photoshop-compatible plug-in containing 15 effects for creating a selection of grain and mezzo styles.
Download (155.9kb):
Hi-Spot
Digital Film FX : A single Photoshop-compatible plug-in filter for high-contrast B&W effects. It will not just convert your images into the standard shades of grey, it will automatically higher the contrast and produce a more dramatic sense of lighting in your scene. Much like the old photos you may have seen in your family albums. A bonus features for darkroom enthusiasts is the ability to lightly tone your B&W print at the same time. Give your photos that ancient sepia look or mix the colour settings to produce your desired monochrome tint.
Download (148.5kb):
G-Force
Digital Film FX : A single Photoshop-compatible plug-in filter for B&W grain effects. It produces results similar to using traditional “fast” B&W camera film, allowing more control than the standard “noise” filters included with most image-editors. Give your photos back some of that artistic texture which seems to be sadly missing these days! Ideal for both landscape scenes or portraits. For best results use with high-resolution images of at least 2 megapixels.
Download (148.9kb):
Techni-X
Digital Film FX : A single Photoshop-compatible plug-in filter for very high contrast effects. It bleaches out most of the mid-tone greys, leaving crisp dark blacks and bright clean whites. It will produce clear B&W images with limited tones, which are suitable for cheap reproduction via the office photocopier or when published in newsprint, as these methods normally loose image definition when trying to reproduce standard colour photographs. Although mainly designed for this “technical” purpose, you can also have fun by adding strong colour-casts within the plug-in!
Download (147.7kb):
NightScope
Digital Film FX : A single Photoshop-compatible plug-in filter for adding a basic “night-vision” effect to your digital photographs and/or 2D and 3D computer-generated images. It first removes all colour from the picture and gives a very slight blur to indicate the film is trying hard to focus in a low-light situation. Then you can choose to add grain either keeping it B&W or mixing separate red, green and blue channels to vary the effect. You can also produce a strong overall colour cast using the RGB sliders provided. Works best with dark night-time photographs that have minimal areas of bright background elements in the scene.
Download (179.2kb):
Pseudo-IR
Digital Film FX : A single Photoshop-compatible plug-in filter for creating a similar look when using traditional B&W infra-red film. It is not an exact match but will provide you with a quick and easy way to re-create the effect digitally using your standard colour photographs. The RGB sliders will also allow you to tint the overall image if you wish. For best results use this filter on landscape scenes. It is also quite effective on certain architectural elements too. Not really suitable for portrait subjects though.
Download (178.0kb):
SkyGrad
Digital Lens FX : A single Photoshop-compatible plug-in filter for tinting the sky area of your photographs. Ideal if you need to change the “mood” of your scene, brighten-up a dull day or make a darker overcast sky for dramatic effect. The filter will overlay a coloured gradient from the top of your image fading to transparent at the bottom. You can specify the colour of the tint via three RGB sliders plus you can adjust the brightness with the exposure setting.
Download (147.7kb):
BW-Plus
Digital Lens FX : A single Photoshop-compatible plug-in filter for quickly turning your colour images into greyscale, but with the added option of using a coloured optical lens filter as you would in traditional B&W photography. The different colours will change the tonal range during the greyscale conversion : for example, a red filter will lighten the red, magenta and yellow areas plus darken the green, blue and cyan in the photo. There are 6 preset effects to choose from using a simple.
Download (138.1kb):
FastFix
Darkroom Correction Tool : A single Photoshop-compatible plug-in filter to help you quickly access the most common image-enhancement controls though one easy-to-use dialog. You can modify the brightness, contrast, saturation, red/cyan, green/magenta and blue/yellow balance settings all at the same time. A simple concept but a surprisingly useful filter that will help you fix many of your photographic problems.
Download (175.5kb):
Photoshop Actions
Handy productivity tools in Photoshop *.atn format. They help you to speed-up the repetitive tasks that you often have to perform on a daily basis. This collection only has 3 sets of resizing actions so far, but I will add many more sets to this pack in future so keep an eye on the updated download.
Download (3kb):
Mini Mono Fill
A collection of 400 greyscale computer-generated seamless tiles. Import them into your 2D or 3D graphics programs and use as pattern fills, displacements maps, bump maps, etc. All tiles are 50 x 50 pixels in size and are supplied in JPG format for maximum compatibility with a wide variety of software and operating systems.
Download (567.2kb):
Essa é pro alex… experimenta o Gforce
PB & Ruido!
Estes plug-ins e muito mais já estavam disponíveis aqui…
Eu não tinha visto ainda e baixei o G-FORCE, achei bem legal.
Uma dica: Ele faz a conversão para PB automaticamente, certo? Daí vc pode aplicar o grão, mas se vc quiser aplicar esse grão numa imagem em cores vai aí uma dica:
  1. Abra a imagem
  2. Duplique a Layer (Ctrl+J), mude a BLENDING de NORMAL para LUMINOSITY
  3. Agora sim, aplique o FILTRO G-FORCE nessa Layer e tudo ficará em cores, ok?
Abraços, Fred Filho.
Estes plug-ins e muito mais já estavam disponíveis aqui... http://www.mundofotografico.com.br/forum/index.php?showtopic=8109
:doh:
