Fujifilm X-T4 atualização de Firmware
firmware Ver.1.10
Data: 17/09/2020
Camera performance used with the XF50mmF1.0 R WR is optimized.
The phenomenon is fixed that in a multiple-flash shooting where the EF-X500 is used as a commander, flashes in some groups sometimes don’t fire correctly. Also in case the EF-X500 is used as a commander and the EF-60 as a remote flash, upgrade the camera firmware to the latest version.
Fix of minor bugs.
Fuji Rumors apresentou hoje um vazamento de informação do canal do YouTube Fuji Guys sobre a versão de firmware 1.20.
Porém o link do vídeo no canal do YouTube está como privado.
Informações disponíveis no momento:
-Display of IP ADDRESS in Setup Menus > CONNECTION SETTING > INFORMATION is added.
-New Auto Power OFF tab setting. It will turn off the camera when the camera gets too hot. You can also set it to “high” to let the camera run until the maximum allowed temperature
-minor bug fixes
Essa versão de firmware deve ser liberada logo.
31/03/2020 - firmware Ver.1.20
Quanto aos detalhes das melhorias, agora tem um “Guia de novos recursos do X-T4” disponível para download (PDF). Praticamente um adendo ao manual.
Link para download em inglês:
Link para download em espanhol:
Não tem versão em português.
Melhorias:
1. “AUTO POWER OFF TEMP.” option is added in the “POWER MANAGEMENT” menu.
  • When the firmware is upgraded from ver.1.10 or Ver.1.11, “HIGH” mode in the POWER MANAGEMENT” menu is selected. We would recommend use of a tripod because the temperature of a part of a camera body can become hot although the shooting time becomes longer.
    If you take a movie continuously on hand, we would recommend you set the “AUTO POWER OFF TEMP.” to “STANDARD” although the shooting time becomes shorter.
    *Resetting the SETUP menu makes the “AUTO POWER OFF TEMP.” option changed to the “STANDARD” mode. If you want to take a movie longer, change the setting to the HIGH” mode.
2. Display of “IP ADDRESS” in Setup Menus > CONNECTION SETTING > INFORMATION is added.
3. Improvement of shutter speed setting for TTL slow sync flash shooting
In P and A mode, this firmware makes the slowest shutter speed slower than 1/8 sec. for the shooting used in a scene where relatively long exposure is required (ex. a flash shooting with night view background). In case the shutter speed setting is AUTO, the shutter speed becomes max. 4 sec in P mode and max. 30 sec. in A mode.
4. Fix of minor bugs.
Versão 1.21
Data 29/06/2021
The firmware update Ver.1.21 from Ver.1.20 incorporates the following issues:
The phenomenon is fixed that the position of the spot metering is fixed on the center without reflecting the position of the focus area in case the focus mode is MF and the metering mode the spot.
The phenomenon is fixed that an image cannot be played back with a specified file name created by the EDIT FILE NAME function.
Fix of minor bugs.
Download:
Regarding the upgraded firmware for X-T4, X-Pro3 and X-E4
Jul 1, 2021
FUJIFILM Corporation
To our valued customers
Thank you very much for purchasing and using our products.
We have found a malfunction in the upgraded firmware for the three models posted on our website on June 29 2021. Therefore, we temporarily stopped the disclosure of the firmware.
< Applicable models and firmware version>
(1) X-T4:Ver1.21
(2) X-Pro3:Ver.1.21
(3) X-E4:Ver.1.02
In case of PAIRING REGISTRATION is available in SET UP MENU>CONNECTION SETTING>Bluetooth SETTINGS, it is most likely that a camera doesn’t turn on if the eye sensor is used just after you switch it on. *Note Removing and inserting a battery gain will recover the symptom. And this symptom cannot occur if you delete all the pairing registrations.
We plan to release the new firmware for the three models later to fix the symptom.
We would appreciate it if you could understand this situation.
Firmware v1.22
08/07/2021
The firmware update Ver.1.22 from Ver.1.21 incorporates the following issue:
The phenomenon is fixed that in some cases, a camera doesn’t turn on when the PAIRING REGISTRATION is available in SET UP MENU>CONNECTION SETTING>Bluetooth SETTINGS.
Download:
Firmware 1.23
07/10/2021
The firmware update Ver.1.23 from Ver.1.22 incorporates the following issues:
Minor bugs have been fixed.
Firmware 1.30
16/02/2022
・The maximum number of frames that can be stored in a single folder will be changed from 9,999 to 999 with Ver.1.30 or later.
Firmware 1.40
30/03/2022
Revised specification from Ver.1.30 to Ver.1.40
Regarding the detail of the improvements, download the “X-T4 New Features Guide” from our website.
New Features Guide:
XLR microphone adapter* has been supported. As a result, [XLR MIC ADAPTER SETTING] option has been added under the [AUDIO SETTING] in the movie menu as well as [4ch AUDIO PLAYBACK] option has been added under [SOUND SETTING] in the setup menu.
*TEAC TASCAM CA-XLR2d-F” XLR microphone adapters has been supported.
A firmware bug has been fixed, which caused that [WB SHIFT] saved as “CUSTOM” would be disabled by operating the “Q” menu.
Another minor bug has been fixed.
Firmware 1.50
29/06/2022
Revised specification from Ver.1.40 to Ver.1.50
FUJINON lens, XF150-600mmF5.6-8 R LM OIS WR has been available.
The accuracy of AF function has been improved at manual focus mode using “One-Push AF”.
Firmware 1.60
29/09/2022
Novo guia de funcionamento devido as novas funções de controle para zoom e foco que foram adicionadas/modificadas.
Verifique link acima para descrição completa.
Exposure adjustment function for the pre-view image/movie has been enhanced by optimizing the parameters for the exposure control when XF150-600mm is used.
“AF+MF” function has been available even at movie taking.
Fujifilm X-T4 ver. 1.72
Revised specification from Ver.1.71 to Ver.1.72
The firmware bug has been fixed, which caused that the focus cannot be adjusted by operating the Manual Focus Ring during movie recording when using the following lenses.
・FUJINON LENS XF14mm F2.8 R
・FUJINON LENS XF16mm F1.4 R WR
・FUJINON LENS XF23mm F1.4 R
Firmware 2.0
24/05/2023
Esse FW traz diversas correções e a lista é grande:
