Nikon Z5: atualização de firmware
Nikon Z5 firmware v1.10
https://downloadcenter.nikonimglib.com/en/download/fw/401.html
• A Save focus position option has been added to the SETUP MENU. If On is selected, the focus position in effect when the camera is turned off will be restored when the camera is next turned on. This option applies only when the camera is used with Z mount autofocus lenses.
• Improved low-light autofocus detection times for Custom Setting a11 (Low-light AF).
Nada do aumento fps, seria bom de mais para ser verdade.
A galera da astrofoto agradece!
Que burro! Dá zero pra mim!
Sério agora: vi que se trata do ponto de foco, não do foco em si. Minha câmera, mesmo usando lentes AF em foco manual, ao ligar e desligar a câmera, o foco muda. Pensei que fosse algo nesse sentido.
Nikon Z 5 firmware 1.11
Data: 13/07/2021
https://downloadcenter.nikonimglib.com/en/download/fw/415.html
Addressed an issue that would in rare circumstances result in unusually loud noises from the aperture mechanism when the zoom or focus rings on F mount lenses connected via an FTZ mount adapter were rotated.
Nikon Z5 firmware 1.20
10/11/2021
https://downloadcenter.nikonimglib.com/en/download/fw/430.html
• Added support for:
  • FTZ II mount adapters, and
  • NIKKOR Z 24-120mm f/4 S lenses.
    • Improved face/eye detection performance and the visibility of subjects in pictures taken using an optional flash unit.
Nikon Z5 firmware 1.21
27/10/2022
https://downloadcenter.nikonimglib.com/en/download/fw/468.html
Fixed an issue that in rare circumstances resulted in vibration reduction failing to function after the firmware was upgraded to version 1.20.
por favor
ha algum topico aqui no forum sobre escolha entre nikon d750 ou nikon z5 ???
Não tem, mas o que você quer saber sobre esses modelos?
Nikon Z5 firmware 1.40
15/02/2023
https://downloadcenter.nikonimglib.com/en/download/fw/485.html
Added support for the iOS version of NX MobileAir. Use NX MobileAir version 1.0.4 or later.
Added support for MC-N10 remote grips.
Added support for ML-L7 remote controls.
Eye-detection AF is now available during video recording.
[Save focus position] and [Recall focus position] have been added to the roles that can be assigned using Custom Setting f2 [Custom controls] in the [CUSTOM SETTING MENU]. As of February 14, 2023, these options were supported with the following lenses:
NIKKOR Z 70-200mm f/2.8 VR S
NIKKOR Z 100-400mm f/4.5-5.6 VR S
NIKKOR Z 400mm f/2.8 TC VR S
NIKKOR Z 400mm f/4.5 VR S
NIKKOR Z 800mm f/6.3 VR S
Improved eye-detection performance for [Auto-area AF].
Improved the refresh rate for the focus points displayed in live view during subject-tracking and face/eye-detection AF.
The behavior of autofocus during memory recall has been improved to ensure that the focus position will not change in any focus mode even if the shutter-release button is pressed halfway while focus recall is in progress.
Fixed an issue that sometimes caused the camera to stop responding when [Auto] was selected for [Set Picture Control] in the [PHOTO SHOOTING MENU].
Upgrade no AF, fica mais competitiva ainda.
pensei o mesmo! A bichinha parece ser bem competente.
Quem diria, melhora no af da Z5.
Z5 firmware 1.5.0
10/06/2025
• Added support for the power zoom feature on power zoom lenses.
• [русский (RU)] has been added to the languages available via the [Language] item in the [SETUP MENU] for Z 5 cameras sold in the Middle East.
• Fixed the following issues:
  • When an SB-500 flash unit was mounted, changing from spot metering to another metering mode did not change the i-TTL flash control from standard i-TTL fill-flash to i-TTL balanced fill-flash.
  • Viewing other pictures in playback zoom display would fail after zooming out a “tall” picture with a pinch gesture.
download: Nikon | Download center | Z 5 Firmware
