Nikon Z9 : atualização de firmware
Muito positiva a resposta deles. :snack:
Ainda tá dando problema colar as informações sobre a atualização?
Respondi à minha própria pergunta: tá.
Firmware 3.10
28/02/2023
https://downloadcenter.nikonimglib.com/en/download/fw/486.html
Added support for NIKKOR Z 85 mm f/1.2 S lenses.
Improved focus accuracy for low-contrast subjects during burst photography with [Wide-area AF (S)], [Wide-area AF (L)], [Wide-area AF (C1)], [Wide-area AF (C2)], [3D-tracking], or [Auto-area AF] selected for [AF-area mode].
Improved the frame advance rate during burst photography with optional flash units.
Fixed the following issues:
  • The [Retouch] > [Trim] item in the playback “i” menu would in rare cases create distorted copies or not permit selection of the desired crop.
  • Copies created by blending a large number of pictures together using the [Retouch] > [Lighten] item in the playback “i” menu would sometimes exhibit a green color cast.
  • Rating pictures during playback zoom would in some instances temporarily corrupt the display.
  • In extremely rare cases, the camera would stop responding.
Um relato de um fotógrafo de pássaros sobre o último firmware.
[/img]
:snack:
Novo firmware.
Frontside feeble grind no skate
Matt Irwing :snack:
Ricci.
Simulações de som de obturador.
Captura automática / esportes
Tudo que foi otimizado ou incluído.
https://www.dpreview.com/news/2835073682/nikon-announces-firmware-v4-0-for-z9-adding-auto-capture-and-more
Firmware 4.10
04/10/2023
https://downloadcenter.nikonimglib.com/en/download/fw/505.html
MELVILLE, NY (October 4, 2023) – Nikon is pleased to announce the release of firmware version 4.10 for its flagship full-frame/FX-format mirrorless camera, the Nikon Z 9.
New dedicated [Birds] and [Airplanes] subject detection options have been added with firmware version 4.10.
The [Birds] option increases overall detection performance for birds. In addition to increased detection and AF performance with complicated and high-contrast backgrounds such as forests and rocky mountains, this option adds the ability to quickly detect birds in various states, including flying, perched, and even those with unique-looking appearances. Tracking performance with rapidly moving birds are also increased for a smooth shooting experience that ensures you will never miss a crucial moment when photographing birds. Adding the same [Airplanes] option built into the Nikon Z 8 enables reliable detection of airplanes regardless of their size. This option offers increased detection capabilities with dark scenes and those that include busy backgrounds.
Firmware 5.0
Vídeo oficial
Nikon lança a versão de firmware atualizada 5.00 para a câmera full frame sem espelho Nikon Z 9
TÓQUIO – A Nikon Corporation (Nikon) tem o prazer de anunciar o lançamento da versão 5.00 do firmware para sua principal câmera sem espelho full-frame/formato FX, a Nikon Z 9.
A versão 5.00 do firmware, a quarta grande atualização desde o lançamento do Z 9, aumenta a usabilidade para fotografia esportiva expandindo as funções Auto Capture e High-Speed ​​Frame Capture+. A fotografia de retrato também foi aprimorada para uma captura mais eficaz das imagens que os fotógrafos desejam, com as novas funções Suavização de pele e Equilíbrio de impressão de retrato, e o novo Controle de imagem de retrato em tons ricos que permite a renderização de detalhes da tez do sujeito com tons ricos. Além disso, a evolução do Z 9 continua com a melhoria da operabilidade alcançada em resposta ao feedback dos profissionais que solicitam maior velocidade e eficiência.
A Nikon irá satisfazer continuamente as necessidades dos utilizadores através de atualizações de firmware que expandem a funcionalidade das suas câmaras.
Recursos principais da versão de firmware 5.00 para o Z 9
  1. Funções expandidas aumentam a flexibilidade para fotografia esportiva
    Uma função de reserva que permite aos usuários especificar antecipadamente a data/hora de início da filmagem e a duração foi adicionada à Captura Automática. Isto ajuda a reduzir o consumo da bateria para uma captação mais eficiente, mesmo quando a câmara tem de ser posicionada e configurada bem antes de ser realmente utilizada. A flexibilidade da captura automática também foi aumentada para permitir que os usuários expandam sua gama de expressão com suporte para fotografar usando a área de imagem DX (24×16), a adição de um modo de detecção de assunto AF [Aviões] e exibição de uma moldura amarela quando a câmera está no modo de espera para fotografar.
Além disso, um item de baixa velocidade [C15] foi adicionado às opções High-Speed ​​Frame Capture+ para maior usabilidade com disparo contínuo. Além disso, predefinições de frequência para iluminação LED comum e letreiros foram adicionadas à função de Redução de cintilação de alta frequência, facilitando a escolha da velocidade ideal do obturador e reduzindo com eficiência os efeitos da cintilação de alta frequência.
  1. Funções que permitem a renderização de retratos que melhor atendem à intenção do usuário
    Foi adicionado um controle de imagem de retrato de tons ricos adequado para criar imagens básicas em situações que exigem retoques, como fotografia de casamento e estúdio. Além disso, foram incorporadas uma variedade de funções projetadas para melhorar a fotografia de retratos, incluindo Equilíbrio de impressão de retrato e Suavização de pele. Além disso, a Nikon oferece lentes NIKKOR Z, incluindo a NIKKOR Z 50mm f/1.2 S, NIKKOR Z 85mm f/1.2 S e NIKKOR Z 135mm f/1.8 S Plena, todas elas suportando a captura de retratos que expressam com precisão a intenção do usuário.
Além disso, a conveniência geral foi aumentada com a capacidade de usar a luz LED contínua da Profoto A10 como um iluminador auxiliar de AF* 1 e a adição de uma opção [Preferir ponto de foco (prioridade de rosto)] para avançar o quadro quando rever imagens exibidas com o zoom de reprodução ativado.
  1. Outros recursos adicionados para melhor operabilidade
    Uma variedade de melhorias na operabilidade foram alcançadas para obter maior velocidade e eficiência que atendem às necessidades dos profissionais.
Quando [Bancos de menu estendidos] está ativado, os usuários agora podem gerenciar os modos de disparo para modo de foto e modo de vídeo, que estavam vinculados anteriormente, separadamente.
A visibilidade é melhorada com uma opção que permite ao usuário ajustar o peso da borda do ponto de foco.
O foco manual agora é possível com visualização ao vivo de abertura máxima no modo de foco manual.
Foi adicionada uma função que permite ao usuário cancelar o zoom quando o modo de foco está definido para foco manual e a visualização através da lente é ampliada pressionando o botão de liberação do obturador até a metade.
A operabilidade do zoom de alta resolução foi melhorada e os colchetes da área AF exibem a cor quando o assunto está em foco foram alterados de vermelho para verde.* 2
O número de funções que podem ser atribuídas a controles personalizados foi aumentado, assim como o número de controles que podem ser personalizados.
A adição de um item [Personalizar opções de retoque] permite ao usuário escolher as funções exibidas no menu de retoque.
As opções [Reprodução em loop], [Aguardar antes da reprodução] e [Velocidade de reprodução em série automática] foram adicionadas para reprodução de uma série de imagens capturadas com uma sequência de disparos contínuos.
A velocidade de reprodução de todos os vídeos agora pode ser especificada antecipadamente no menu i ([Velocidade original], [Velocidade 1/2x], [Velocidade 1/4x]).
O modo de estação Wi-Fi foi adicionado para permitir a conexão ao SnapBridge sem ocupar toda a conexão Wi-Fi de um smartphone.
Quando o punho remoto MC-N10 está conectado à câmera, o acessório ATOMOS AirGlu, UltraSync BLUE, agora também pode ser conectado via Bluetooth ao mesmo tempo.
Read more: Nikon releases a major firmware update version 5.00 for the Nikon Z9 camera - Nikon Rumors
A Nikon também atualizou o APP SnapBridge versão 2.11.0 com a função Easy Shooting Setup, que permite aos usuários definir as configurações de disparo da câmera em um smartphone.
A Nikon Corporation (Nikon) tem o prazer de anunciar o lançamento da versão 2.11.0 do SnapBridge, que traz novas funções, como Easy Shooting Setup, que permite aos usuários definir as configurações de disparo da câmera adequadas a uma cena ou assunto específico diretamente de um dispositivo inteligente. dispositivo* 1 , foram adicionados.* 2
A nova função Easy Shooting Setup pode ser usada tocando em [Easy Shooting Setup]* 3 na guia da câmera SnapBridge, selecionando um assunto ou situação principal e decidindo como deve ser a saída, como ter um leve desfoque fundo ou desfoque de movimento. Ele permite que mesmo aqueles que não estão familiarizados ou não têm certeza sobre as funções da câmera e termos relacionados criem facilmente configurações de fotografia da câmera que alcançam os resultados desejados. As configurações são aplicadas no momento em que são enviadas para a câmera, permitindo que os usuários comecem imediatamente a fotografar com elas. O Easy Shooting Setup também fornece dicas para cenas e assuntos disponíveis, como pessoas, paisagens e animais de estimação, para ajudar os usuários a alcançar melhor os resultados pretendidos. Além disso, as configurações de fotografia favoritas podem ser atribuídas a uma das posições de configuração do usuário* 4 .
Read more: Nikon released version 2.11.0 of the SnapBridge app - Nikon Rumors
Será que sai pra Z8? Vejo que a Nikon coloca muita coisa na Z9, mas na Z8 tem deixado de lado muita coisa…
Outra coisa que acho impressionante a Nikon não fazer e não consigo entender porque, é o auto-capture em RAW, só tem em JPEG.
Na verdade, há funções que foram introduzidas na Z8 por firmware, que a Z9 ainda não tem.
Mudança de pixel apenas em Z8/Zf. Z8 permite acesso a imagens HEIF em vez de JPG na fotografia - ainda não disponível no Z9.
Sério? Ambas câmeras me parecem recheadas de funções de foto e vídeo. E o valor de ambas me parece competitivo.
