TAMRON Announces Development of Second-generation Fast-Aperture Standard Zoom Lens for Sony Full-Frame Mirrorless Cameras
New 28-75mm F2.8 G2 offers significantly improved optical and autofocus performance and new function customization
August 4, 2021, Commack, NY – Tamron announces the development of a second generation fast-aperture standard zoom lens for Sony E-mount full-frame mirrorless cameras: 28-75mm F/2.8 Di III VXD G2 (Model A063). The lens is expected to launch in 2021.
Overview of the 28-75mm F/2.8 Di III VXD G2 (Model A063) featuresThe 28-75mm F2.8 G2 is the successor of the 28-75mm F/2.8 Di III RXD (Model A036), a popular zoom lens that has earned high evaluation worldwide. It reflects the fruits of continuous evolution and customer-focused refinement. Retaining the well-received compact size of its predecessor, the new 28-75mm F2.8 G2 incorporates a new optical construction based on a design that has been revamped to enhance imaging performance and its features are compatible with the latest model digital cameras that offer increased resolution. The AF drive, TAMRON’s VXD (Voice-coil eXtreme-torque Drive) linear motor focus mechanism, is adopted to deliver higher autofocus speed with greater precision. With the MOD (Minimum Object Distance) of 7.1” at the wide end and a maximum magnification ratio of 1:2.7, the lens boasts advanced close-up shooting performance. Additionally, it features a new design in the pursuit of enhanced operability and ergonomic texture. TAMRON pioneered the category of compact fast-aperture standard zoom lenses for mirrorless cameras and the new 28-75mm F2.8 G2 truly is a next-generation lens for everyday use.
The new lens supports the full array of frequently used angles-of-view including wide-angle, standard, medium telephoto and telephoto, making it easy to compose the perfect shot without changing lenses or your position from the subject.
Originally developed software ‘TAMRON Lens Utility’ for lens function customization
This lens is compatible with the new ‘TAMRON Lens Utility’ software originally and uniquely developed by TAMRON. TAMRON Lens Utility can be operated via your computer by connecting the lens from its Connector Port via the optional TAMRON Connection Cable . Users can customize the functions and update the firmware through the lens rather than through the camera. The personal customization gives flexible shooting options to match the shooting situation such as still photography or videography.
(Functions of TAMRON Lens Utility)
Focus Set Button settings
A-B Focus: Set 2 focus positions (A and B) and make the focus automatically shift between A and B
Focus Preset: Set your desired focus position and move the focus to the recorded point by a click
Switch Focus Ring Function (Focus/Aperture): Switch Focus Ring Function from focus adjustment to aperture adjustment
Assign function from the camera: Assign custom functions from the camera body to the Focus Set Button
*The function of Focus Set Button can be cleared
Focus Ring settings
MF Ring Rotation: Change the rotation direction of the focus ring
MF Method: Choose the method of focus operation when using the focus ring
Firmware update
Main features
Best image quality in standard zoom lens class
Fast, quiet VXD linear motor for high-speed and high-precision autofocus
MOD (Minimum Object Distance) of 7.1” at wide end and maximum magnification ratio of 1:2.7 for creative close-ups
New design provides enhanced texture and greater user-friendliness
Lightweight, compact design with emphasis on ease of use, plus 67mm filter size
O casamento Tamron e Sony está dando muito certo; que assim continue rsrsrs. Impressionante a evolução da Tamron de 2016 pra cá; eles tem lançado lentes que a concorrência não tem coragem de lançar !
Sony tem um leque de lentes de terceiro tão boa que quase se faz inexistente a necessidade de lentes Sony. Única razão que eu tenho Sony é porque os 2 mm extra da minha 12-24 salvam minha pele no meu job de Real State Photography.
Se essa G2 sair mesmo, o preço da G1 vai ficar mais interessante. Hoje, não tem como não recomendar a A7III como melhor kit para quem quer migrar para ML justamente de empresas como Tamron, Samyang e Viltrox.
Conheci um video-maker que era Nikonzeiro, migrou de DSLR pra mirrorless, e vendeu todo o set pra migrar pra Sony. Motivo: entregava praticamente os mesmos resultados, mas o valor de 3 lentes da Tamron 12-28, 28-75 e 70-180 2.8, não comprava duas lentes dessas pra Nikon equivalentes. O custo benefício de mirrorless da Sony é infinitamente melhor, nem se compara.
Minha 70-200 2.8 tem mais que isso de idade e está firme e forte. E demorou para chegar a versão II. Mas agora as empresas descobriram outra forma de ganhar dinheiro, que é “atualizando a linha” de lentes muito mais rapidamente. Basta colocar na propaganda “novo motor de foco mais silencioso e rápido, nitidez aparefeiçoada, menos CA” e pronto…vende :hysterical:
Concordo plenamente!
Basta ver a Canon 24-70 2.8 L : a primeira versão é um tanque de guerra! Dá para usar por anos de forma profissional sem problema. Já a versão II, toda moderna e com o marketing de “nitidez, foco, ca, etc” tem problema no flat cable que quebra (normalmente com 2 anos de uso profissional)
Li um review sobre essa lente, muito boa e com um cxb ainda melhor que a primeira versão.
Achei interessante que na câmera em que foi testada (a7iii) as correções de vinheta e distorção podem ser ativadas na própria câmera, claro que apenas jpeg´s.
Será por que a Sony é sócia da Tamron?
Alguém aí que tem Sony, com por exemplo uma lente Sigma Art elas podem ser ativadas??
