Topaz Labs - Denoise AI - atualizações de versões.
Topaz Labs - Denoise 3.x - atualizações de versões.
3.1.1
19/05/2021
Mac e Windows
Fixes:
Fixed metadata not saving back to Lightroom
v3.1.2
03/06/2021
Change log
Fixed app not being able to open on older hardware
Fixed crash when memory usage was not set correctly
Fixed crash when writing CFA EXIF tags in TIFF/DNG images
Fixed Severe Noise not allowing 0 on the sharpness slider
Fixed previously proced image appearing in background of fully zoomed out image
Fixed slider not matching mouse position
Fixed masking brush not matching drawn strokes
Changed estimated time remaining so it doesn’t jump around as much
Added support for transparency masks in DNG output when input is 4 channel image
Known Issues:
DPI values sometimes do not save correctly
GPS values when saving to Lightroom may not save correctly
Saving an image while zoomed in before a model initializes can cause saving to get stuck
v3.3.1
30/09/2021
Change log:
Fixed Lightroom template not installing on Mac
– 3.3.0 to 3.3.1 update will need to open Standalone in order to have lrtemplate copied correctly
– 3.2.0 or lower to 3.3.1 should have lrtemplate installed automatically
– Make sure to close Lightroom while installing or restart after installing
– You may need to reset your external editor in preferences
Fixed bad error message when loading certain unsupported RAW files
v3.3.2
01/10/2021
Change log
Fixed Photoshop not allowing manual updates in split or side by side view
Temporarily removed Edge Aware in masking due to crashes
Versão 3.6.1
16/03/2022
Versão 3.7.0
22/06/2022
