Como calibrar monitor corretamente
Senhores, adquiri um notebok HP G42 e estou apanhando feio para calibrar as cores do mesmo, a impressão que dá é que a tela não chega nunca ao branco real. Alguém tem alguma dica para solucionar esse problema?
:snack: :snack: :snack:
Acredito que a única forma de calibrar de fato qualquer monitor seja utilizando um espectrofotômetro.
http://forum.mundofotografico.com.br/index.php?topic=29032.0
http://forum.mundofotografico.com.br/index.php?topic=55190.0
Não entendo e nem pesquiso muito sobre nb, mas a tela deste é IPS? Se não for, mesmo calibrado (no que for possível) vc pode errar na “mão” no tratamento… eu uso um monitor IPS no nb, dá muuuuita diferença
Só se for um espectrofotômetro industrial/científico…
Espectrofotômetro comum(i1Photo Pro 2/ColorMunki Photo) não consegue ler adequadamente
os tons mais escuros dos monitores como um colorímetro(i1 DisplayPro/ColorMunki Display).
Do http://www.colorwiki.com/wiki/Profiling_Devices_for_Monitors
“Because spectrophotometers read a large number of bands, instead of just a few, they are
considered to be more accurate than colorimeters. (They are also more expensive.)
However, there is a major drawback. Because they read more bands of light, they will tend
to introduce more noise into the mix. This is not much of a problem until you get down to
measuring things like shadow detail and blacks. Imagine you’re a spectrophotometer, dangling
off the front of a display and you’re asked to measure a black patch. Well, there won’t be
much of anything there to read, but you give it your best. You gather all the data from some
36 bands of wavelengths and because of digital noise and sensor dust, that will add to your
report of how bright black is. For this reason, spectrophotometers tend to not measure shadow
detail as dark as most colorimeters do. For example, the Monaco Optix (DTP-94) is famous for
getting great shadow detail. It even has some noise-reduction circuitry built into it.”
Calibrar se faz com um calibrador+software, o problema é que a maioria
dos noteboks a tela é uma porcaria e calibrar não resolve…
O ideal é usar o notebook com um monitor externo IPS, o melhor custo-benefício
hoje é o LG 25UM58-P.
Queria aproveitar pra fazer duas perguntas sobre monitores / calibração, já que o Pictus (que parece que saca dessa área) respondeu. Mas vai pra todo mundo também:
  1. Existe algum notebook que seja ideal para edição, fora os caríssimos Apple? Que a tela não seja aquela bagunça cheia de reflexos? Fiz um teste de tethering semana passada e quis jogar meu Sony Vaio no lixo, constatei que a tela do celular é mais confiável pra isso. Cheguei a considerar até um Ipad.
  2. Como exatamente acontece do monitor “descalibrar”? Eu achei uns artigos em inglês mas nunca entendi direito. O que faz que as cores, contraste, etc, se modifiquem e cheguem a mostrar algo que não é totalmente fiel as cores?
    Me intriga isso pois sempre achei que, por ser mecânico, se deixasse o brilho e contraste do monitor em determinado nível ele ficaria lá até eu mexer novamente.
Valeu!
Pictus, não sei se entendi direito. Eu pensava que o ColorMunki Photo fazia tudo o que o ColorMunki Display faz + criar profiles ICC para impressão.
Mas pelo o que entendi, para calibrar o monitor, o ColorMunki Display é melhor que o ColorMunki Photo? É isso mesmo?
Adrianojsmoreira,
1- The laptops with the best displays - Notebookcheck Review
http://forum.mundofotografico.com.br/index.php?topic=70683.0
2- Conforme envelhece a resposta do painel muda alterando o balanço dos canais RGB, varia de acordo com
a tecnologia.
Shida,
Sim, sendo que o ColorMunki Display é travado pela X-rite para funcionar somente com o software default
da X-rite, funciona com o Argyll+DispCAL via um “hack”, não funciona com o software da Dell/NEC/BenQ/Eizo
para calibrar o LUT interno dos monitores com este recurso, para estes modelos tem que ser o i1Display Pro.
No caso da Dell são os monitores com PremierColor(wide gamut).
Eu tenho um modelo mais novo do terceiro da lista e, mesmo que ele esteja no mesmo número dos MacBooks, a imagem no monitor externo é significativamente melhor. Meu monitor externo é bom, mas nem é essa coca-cola toda: Um BenQ GW2765HT.
Segue a recomendação do Pictus: monitor bom é monitor externo.
