Fuji X-E4 atualização de firmware
Ver. 1.01
The firmware update Ver.1.01 from Ver.1.00 incorporates the following issues:
A camera doesn’t recognize an Apple Silicon Mac via a USB cable.
Fix of minor bugs.
Download:
Regarding the upgraded firmware for X-T4, X-Pro3 and X-E4
Jul 1, 2021
FUJIFILM Corporation
To our valued customers
Thank you very much for purchasing and using our products.
We have found a malfunction in the upgraded firmware for the three models posted on our website on June 29 2021. Therefore, we temporarily stopped the disclosure of the firmware.
< Applicable models and firmware version>
(1) X-T4:Ver1.21
(2) X-Pro3:Ver.1.21
(3) X-E4:Ver.1.02
In case of PAIRING REGISTRATION is available in SET UP MENU>CONNECTION SETTING>Bluetooth SETTINGS, it is most likely that a camera doesn’t turn on if the eye sensor is used just after you switch it on. *Note Removing and inserting a battery gain will recover the symptom. And this symptom cannot occur if you delete all the pairing registrations.
We plan to release the new firmware for the three models later to fix the symptom.
We would appreciate it if you could understand this situation.
Firmware v1.03
08/07/2021
The firmware update Ver.1.03 from Ver.1.02 incorporates the following issue:
The phenomenon is fixed that in some cases, a camera doesn’t turn on when the PAIRING REGISTRATION is available in SET UP MENU>CONNECTION SETTING>Bluetooth SETTINGS.
Download:
Firmware 1.04
07/20/2021
The firmware update Ver.1.04 from Ver.1.03 incorporates the following issues:
Minor bugs have been fixed.
Dúvida noob, a última versão do firmware incorpora junto as melhorias das atualizações anteriores ou preciso baixar cada uma delas?
Basta atualizar para a última versão.
Firmware v1.10
28/02/2022
Revised specification from Ver.1.04 to Ver.1.10
The following specification has been revised to improve compatibility with SDXC memory card format.
The maximum number of frames that can be recorded in a single folder has been changed from 9,999 to 999.
If you are using a macOS computer to process recorded files in the SDXC memory card, make sure to follow the procedure below before upgrading the firmware. Follow the instructions in “II-2. If using an SDXC memory card with existing files or one that has not been recently formatted:” in the article titled “Important notice for consumers processing FUJIFILM digital camera files using macOS” that was published on Feb. 2 in this web site and then format the SDXC memory card before using it.
Firmware 2.0
24/05/2023
Esse FW traz diversas correções e a lista é grande:
