FUJI X-T200 atualização de firmware
versão 1.11
Segundo a Fuji apenas correções de pequenos erros.
versão 1.12
The firmware update Ver.1.12 from Ver.1.11 incorporates the following issues:
Image quality displayed after one frame delete is improved.
Fix of a minor bugs
versão 1.13
Data 29/06/2021
Fix of minor bugs.
Download:
Versão 1.15
05/11/2021
The firmware update Ver.1.15 from Ver.1.13/1.14 incorporates the following issues:
The problem that the lateral lines rarely appear on the EVF image when the shutter button is pressed halfway has been fixed.
Minor bugs have been fixed.
download:
Versão 1.16
27/07/2022
Revised specification from Ver.1.15 to Ver.1.16
The firmware bug has been fixed, which caused that the following phenomena occurred rarely in combination with X-mount lenses from other manufacturers.
・When shooting with “High-speed Burst” function at “AF-C” setting, it becomes out-of-focus using TAMRON:17-70mm F/2.8 Di Ⅲ-A VC RXD (Model B070) with the above models.
・When zooming from the T end to the W end, the “hunting” occurs in the pre-view screen, which affects movies as well as still photos recorded in this condition using TAMRON:18-300mm F/3.5-6.3 Di III-A VC VXD (Model B061) with the above models.
Other minor bugs have been fixed.
