Fujifilm GFX100S: atualização de firmware
firmware v1.10
30/06/2021
Addition of White Balance and ISO metadata to RAW footage
Added White Balance / ISO metadata to RAW footage, output to Atomos Ninja V HDR Monitor Recorder via HDMI. The footage is recorded as Apple ProRes RAW files and White Balance / ISO can be adjusted in Final Cut Pro.
Improvement of Custom mode function
Changes to the functioning of custom modes have altered how custom settings banks are created and edited using IMAGE QUALITY SETTING >DIT/SAVE CUSTOM SETTING and MOVIE SETTING > EDIT/SAVE CUSTOM SETTING in the shooting menu. You can register/edit after selecting the custom number from C1 Through C6.
The phenomenon is fixed that an image cannot be played back with a specified file name created by the EDIT FILE NAME function.
Fix of minor bugs.
Download do FW e do guia com os novos recursos:
Firmware 1.20
07/10/2021
The firmware update Ver.1.20 from Ver.1.10 incorporates the following issues:
Regarding the details, download the “GFX100S New Features Guide[Ver.1.20]” from our website.
  1. GFX100S will be able to output the RAW video data to Blackmagic Design’s Video Assist 7” 12G HDR and Video Assist 5” 12G HDR as “Blackmagic RAW” through HDMI up to 4K/29.97P 12bit (see Note-2 below)
•New firmware with this feature is supposed to be released by Blackmagic Design.
•RAW video data gives maximum flexibility for exposure adjustment and color grading in post-production for professional videographers.
Besides, simultaneous output of RAW with Film Simulation / F-Log / Hybrid Log Gamma (HLG) to SD card in the camera is also available.
Note-1:GFX100/100S records “Blackmagic RAW” only with Blackmagic Design’s Video Assist 7”12G HDR and Video Assist 5” 12G HDR (as of Oct. 7, 2021).
Note-2:This video RAW data is compatible with 4K (3840×2160) 29.97P/25P/24P/23.98P(Not compatible with FHD).
  1. The electronic level display will work in wider range of the tilt angle, so that you can use the electronic level on the LCD even if you tilt the camera more than that with the current firmware.
  2. Minor bugs have been fixed.
Firmware 1.30
16/02/2022
・The maximum number of frames that can be stored in a single folder will be changed from 9,999 to 999 with Ver.1.30 or later.
Firmware 1.31
30/03/2022
Revised specification from Ver.1.30 to Ver.1.31
The firmware bugs have been fixed, which caused a EVF display failure when the “FRAME RATE PRIORITY” was selected in the [BOOST] menu by operating through the following menu flow.
[POWER MANAGEMENT] ➔ [PERFORMANCE] ➔ [BOOST]
Firmware 1.32
29/06/2022
Revised specification from Ver.1.31 to Ver.1.32
The accuracy of AF function has been improved at manual focus mode using “One-Push AF”.
Firmware 2.0
24/05/2023
  1. The firmware for each model supports new application software “FUJIFILM XApp” for GFX and X series cameras.
“FUJIFILM XApp” is the advanced application software for the current one, “FUJIFILM Camera Remote”, with which wireless communication becomes more stable and faster so that images and movies transportation from the camera becomes more smooth and comfortable with the smartphone and tablet terminal.
Moreover, the operation with the smartphone and tablet terminal becomes much simpler than the current application software, since all the data transportation operations, except for the “Bluetooth Pairing” between camera and the application software required at the first time only, are completed with the smartphone and tablet terminal.
Adding on the “Live View Mode” and access/download functions of the data in camera, several new functions are available, such as “Backup/Restore” to store the setting data in the shooting and setup menus, “Timeline” to review the shooting information of the camera/lens, shooting count/location, etc. and “Activity” to show the accumulated summary of the shooting count total, film simulation usage, etc., which should make GFX and X series cameras attractive more and more.
Note-1: Please see NEWS RELEASE for the details of “FUJIFILM XApp”.
Fujifilm releases the FUJIFILM XApp for the GFX / X Series of digital cameras
Note-2: “FUJIFILM XApp” works with iOS/iPad OS 13 or later and Android OS 11 or later.
Please download the “FUJIFILM XApp” from the following site by selecting the OS version of your smartphone / tablet terminal and the camera.
“FUJIFILM XApp” Download Site
Note-3: “FUJIFILM XApp” will be available as soon as it is ready.
  1. “AREA SETTING” has been added in the “USER SETTING” of the Setup menu, which changed the operation procedure for the initial setting and “TIME DIFFERENCE” setting as follows.
・24 hours display can be selected in “DATE/TIME”.
・Your living location can be selected with the world map as well as “Saving time” can be on and off in “AREA SETTING”.
・“LOCAL” can also be selected with the world map in “TIME DIFFERENCE”.
Note-1: “ARIA SETTING” and “DATE/TIME” menus appear when turning on the camera right after firmware upgrade. So please set up the above items in these menus.
  1. “RESET” function in the Setup menu will change.
・“AREA SETTING” has been added on the list that would not be reset in “SET-UP RESET” function.
・“INITIALIZE” function has been added to reset all settings to default values, other than except for custom white balance.
  1. Some of the menu related to the wireless connection changed as follows.
・“Bluetooth SETTINGS” in “CONNECTION SETTING” of the Setup menu has been changed to “Bluetooth/SMARTPHONE SETTING” and “IMAGE TRANSFER WHILE POWER OFF” has been added in this menu.
・“AUTO IMAGE TRANSFER” has been changed to “AUTO IMAGE TRANSFER” and “SMARTPHONE SYNC. SETTIN” has been changed to “SMARTPHONE LOCATION SYNC” for each.
  1. Some of the menu items of “GENERAL SETTINGS” in “CONNECTION SETTING” of the Setup menu has been change as follows.
・“NAME” and “RESIZE IMAGE FOR SMARTPHONEH 3M” has been moved into “Bluetooth/SMARTPHONE SETTING” menu.
・“GEOTAGGING” has been moved into “SAVE DATA SET-UP” menu.
・“LOCATION INFO” has been moved into “SCREEN SETUP” menu.
・“〔Wi-Fi〕 BUTTON SETTING” has been moved into “BUTTON/DIAL SETTING” menu and changed to “Fn1 BUTTON SETTING”.
  1. “Bluetooth Pairing Registration” has been added in “FUNCTION (Fn) SETTING” while pushing and holding the DISP/BACK” button, which changed the procedure to connect to the smartphone.
  2. Even under busy Wi-Fi environment, the connectivity between the application for a smartphone (FUJIFILM Camera Remote) and a camera is improved.
  3. The firmware bug has been fixed, which caused that the color banding rarely appeared in the recorded image with high sensitivity and long exposure setting, such as shooting starry sky in the night.
  4. Other minor bugs have been fixed.
