. smaller than X-T4
. Fujifilm X-S10 with 26 Megapixel X-Trans Sensor
. has IBIS
. old NP-W126S battery (and not the new NP-W235 battery)
. Fuji’s First Mid-Range Camera with a Deep Grip
. Full AUTO Mode will Capture also RAW files
. [b]split screen ability[/i]…"
“But a new claim from the reliable Fuji Rumors suggests “it will be Fuji’s first mid-range camera with a deep grip”, which would be place it more in the lineage of the company’s first IBIS-equipped camera, the Fujifilm X-H1.”
Na verdade, será uma nova câmera, pra qual estamos tentando achar paralelos. Não creio que vá vir, por exemplo, com o LCD em cima, único da X-H1 entre as APS-C.
[i]. The Fujifilm X-S10 will be an APS-C mirrorless interchangeable lens camera…"
. the upcoming Fujifilm X-S10 will have an SLR styled body. Hence, it’s not a rangerfinder alike camera such as X-E3, X100 or X-Pro3…"
. smaller than X-T4
. Fujifilm X-S10 with 26 Megapixel X-Trans Sensor / X-Processor 4
. has IBIS (5-axis in-body image stabilization that has an effect of up to 6.0 steps)
. 4K30p video, full HD 240p slow motion video, continuous shooting performance of 30 frames / second
. 1.04 million dot vari-angle liquid crystal
. 18 kinds of film simulation
. split screen ability…"
Segundo os novos rumores, a X-S10 realmente não terá o LCD no lado superior direito:
“…This might explain also why Fujifilm decided to call it X-S10 and not X-H10 (or “mini X-H1“), as the top LCD is one of the unique standout features of the X-H line compared to all other Fujifilm X series cameras…”
O que se sabe da futura X-S10 até o momento (atualizado):
. smaller than X-T4
. there won’t be any top LCD, like there is on the Fujifilm X-H1
. right on the top plate there will be also a Q button, an ISO button and a dedicated video button
. There will be the usual MENU, AF-ON, AEL, DISP/BACK, DRIVE, PLAYBACK button
. There is no D-Pad, but there is a Joystick
. There is a front command dial
. There is no focus mode selector (the M-C-S switch)
Desconfio de que a bateria modelo NP-W235 (da X-T4) será usada somente nas linhas X-Tx e X-Hx. Não consigo imaginar aquela bateria em uma hipotética X-Pro 4, por exemplo, rsrsrs
Aliás, um IBIS menor poderá possibilitar sua aplicação nas futuras X-Pro e X-Ex
Eu acho ótimo que hajam os dois tipos ds bateria, assim conseguirmos usar nossas câmeras mais antigas de boas e não perdemos as baterias já adquiridas.
Essas configurações já existem, embora pelo menu Q. O problema é que elas abrangem somente configurações de imagem (compressão dinâmica, cor, nitidez, etc.), não de câmera (tipo/velocidade de disparo, foco, LCD, etc.).
