Nova Pentax K-1 A Full Frame da marca é anunciada.
Demorou mas chegou.
Muito interessante os botões giratórios na parte superior. Dão facilidade e mudam rápido para o que o usuário quer.
Também U1 a U5! Porque alguns modelos top da Nikon não tem isso? !!!
http://petapixel.com/2016/02/17/pentax-k-1-features-not-found-full-frame-dslr/
http://www.pentax.com/en/k-1/
Não tem ninguem comentando, será que o pessoal viu isso aqui???
http://www.dpreview.com/news/2055527036/pentax-k-1-s-pixel-shift-challenges-medium-format-dynamic-range
“The Pentax K-1 has produced one of the best dynamic range performances we’ve yet seen. As our testing of the camera continues, we’ve been looking through the results of our Raw dynamic range test and we’ve been very impressed. And that’s before we looked at the benefits brought by Pixel Shift Resolution mode.”
“In conclusion, the K-1 gives one of the best Raw dynamic range results we’ve ever seen, when shooting in single shot mode and absolutely outstanding results in circumstances where you can use the pixel shift mode. The multiple sampling of the same scene effectively gives a 2EV dynamic range boost, meaning it out-performs both the D810 and the 645Z by a comfortable margin. Less noise (though multiple captures) and multiple 14-bit values at every pixel mean it can give outstanding levels of DR for static scenes where you can use the Pixel Shift mode.”
O pessoal foi pro outro tópico que havia sobre o mesmo assunto… O Koki deu o link.
Sim, eu vi… mas ninguém lá comentou esta noticia tbm, além do que o tópico nem tem “K1” no nome…
Levei a informação para lá!!!
