Improved – When using both SD card slot 1 and slot 2 at the same time, operation becomes unstable in rare cases when using some SD cards.
Improved stability for general performance.
[Enhanced features]
Added support for IMAGE Transmitter 2 (Version 2.6.0)
[Others]
Improved the individual AF fine-adjustment settings to identify the attachment of the HD PENTAX-DA AF REAR CONVERTER 1.4X AW.
[Enhanced features]
Added Astrotracer Type 3. For details refer to the PDF manual.Click here
[Others]
Improved AF accuracy and stability during viewfinder shooting.
[Enhanced features]
Added [KATEN] to Custom Image.
For more details click here
* It can be used when attaching the following compatible lenses.
HD PENTAX-D FA 21mmF2.4ED Limited DC WR
HD PENTAX-DA 15mmF4ED AL Limited
[Others]
* When this update is done, the contents of version 1.41 and earlier will be also updated.
* When this update is done, you will not be able to restore back to version 1.41 or earlier.
