Uma informação para quem está pensando em adquirir um NAS: Synology 2025 modelos série Plus somente com discos da Synology.
Germany, Düsseldorf - 16.04.2025 - Following the success of the high-performance series, the company is now also increasingly relying on Synology’s own storage media for the Plus series models to be released from 2025
For users, this means that starting with Plus Series models released in 2025, only Synology’s own hard drives and third-party hard drives certified to Synology’s specifications will be compatible and offer the full range of features and support.
Fonte: Synology is increasingly relying on its own ecosystem for upcoming Plus models | Synology Inc.
Synology does not manufacture its own drives but packages and markets drives from major manufacturers, including Toshiba and Seagate. As such, Synology’s drives are typically more expensive than third-party models with similar specs.
Fonte: Synology confirms that higher-end NAS products will require its branded drives - Ars Technica
Contraponto:
While currently these hard drives are actually cheaper then their IronWolf counterparts, they are limited in a few key areas, including total size (max at 16TB) and also have the ability for synology to simple lock them out of the entire market.
fonte: Synology requiring drives on all 2025 models - SPACEREX
Para quem tem interesse no assunto vale ver o vídeo abaixo e ler o link acima do blog do SPACEREX.
