Z7 1/2, tipo “Quem quer ser John Malkovich”
Tem a Z5 na fila.
Será? eu acho que essa demora.
tem que fabricar o que vende né? kkkkkk
Viltrox bombando.
Eu nao sei como sera o acordo deles com essas lentes, mas eu vejo o E mount e o L mount, como plataformas que podem tornar cameras mais atraentes tornando mercados mais acessiveis.
https://youtu.be/Do3HrCqP1C4?si=hZbs7biaOB3J-75o 20 2.8 Viltrox review
The Nikon ℤ6 III is expected to be the best camera in its category
Nikon model N2214
New 24.5 MP BSI sensor specialized for low light and high dynamic range
New processing engine (EXPEED 7?)
6k size 6048 x 4032 full-frame 12-bit NRAW
4k60 full ProRes RAW
Full HD movie at 240fps (8-bit crop)
New higher resolution EVF: 5.76m dot
Improved vari-angle LCD screen
14 fps mechanical, 20 fps electronic shooting (RAW, 14 bit)
120fps stills jpeg
37-120min record time
1/16000 shutter speed
Mechanical & electronic shutter
293/297 AF points
Updated focus algorithm (better than ℤ8/ℤ9?)
Near 100% AF coverage of the frame
7 or 8-stop VR (same system as the Nikon ℤf)
Pixel-shift (previously reported here)
CFexpress+SD memory cards
PSAM Dial
Hybrid body design between the ℤ6 and ℤ8 (bigger than the current ℤ6/7 but smaller than the ℤ8) – see this post
The playback button is in the same place as ℤ8 (bottom right), as opposed to ℤ6II, which is on the top left side of the camera
Camera body size and overall dimension are similar to the Nikon ℤ6II: 3-5mm longer width becuase of the LCD hinge and a few mm thicker
The overall height (bottom to the EVF) remains the same but the actual camera is 2-3mm taller
The grip button layouts and design look similar to the Nikon ℤ8 apart from the command dial which is the same as the ℤ6II
All other button layouts are the same as the ℤ6II
The ℤ6III logo is on the top, just like on the ℤ8/ℤ9
ℤ logo in the front is also like the ℤ8 but below the current ℤ6II focus sensor
The ℤ6III body overall is about 30-40g heavier than the Z6II
The ℤ6III body inherits the design from the ℤ8 – this is why a few months ago I reported it as a mini-ℤ8 (the Nikon ℤ6III is a mini ℤ8, the Nikon ℤ8 was a mini ℤ9)
USB-C 3.0 (SuperSpeed)
HDMI A version 2.1 (full-size HDMI)
WiFi 2.4/5 GHz, Bluetooth LE Connect support
Better ergonomics compared to the ℤ6
New cooling design
Weight: 700-750g
Battery EN-EL15
Nikon MB-N14 battery pack
Several new features not seen in other Nikon cameras, including online firmware updates
Price: around €3,000 in Europe (less in the US)
Official announcement: next week (June 10-12 )
Shipping is expected to start in mid-July.
The current Nikon ℤ6II will be in production until the end of the year (heavily discounted)
A new version of Nikon NX Studio with support for the ℤ6 III is expected to be released soon
The new ℤ6III will be available as a body only or in a kit with the 24-70mm f/4, 24-120mm f/4, and a third unknown lens
Agora que a Z6 III saiu qual será a próxima câmera?
Z 7III com 50MPX ou mais ?
Z 5 II? ou a Z 6 II passa a ocupar o lugar do que seria a Z 5II?
Z 50II
2 câmeras registradas na Asia codinomes: N2216 e N2312
De acordo com a Nikon Rumors temos:
N2014: Nikon Z9
N2120: Nikon Z8
N1932: Nikon Z7II
N1929: Nikon Z6II
N1710: Nikon Z7
N1711: Nikon Z6
N1933: Nikon Z5
N1912: Nikon Z50
N2121: Nikon Z30
N2016: Nikon Zfc
N2137: Nikon Zf
N2214: Nikon Z6III
N2216: Nikon ???
N2312: Nikon ???
:snack:
Nikon Z7 III de 88 MP :eek: :eek:
“One day during my nap, I dreamed that the Nikon Z 7 Ill is an FX-format 88.48-megapixel BSI CMOS sensor.”
Vai ser tipo a D800 em 2012 com 36mp
Segundo o Mirrorless Rumors a Nikon tem mais 3 câmeras que podem ser anunciadas dentro de 3 ou 4 meses.
Será que sai uma APS-C D500 Z? ![]()
Nossa, nem tinha visto.
A galera está a todo vapor.
Z50 II ?
Está precisando de uma aps-c com Expeed 7.
Seria bem interessante.
Agora resta saber se vai ser uma Z50 II ou uma flagship DX…
