**ColorMunki Smile – Discontinued Mac Support
Mac OS X 10.15 Catalina was released on October 7, 2019. This new Mac operating system requires applications to be 64-bit compliant.
ColorMunki Smile software is a 32-bit application, and will not run on Mac OS X 10.15 Catalina.
There are no plans to develop a 64-bit application for ColorMunki Smile.
To continue to use the ColorMunki Smile on a Mac, you will need to avoid upgrading to Mac OS X 10.15 Catalina.
If you decide to upgrade to Mac OS X 10.15 Catalina, you should consider upgrading to the i1Display Studio or i1Display Pro which are both 64 bit compliant.
Para quem ter esse colorímetro noa atualize para o OS X Catalina, pois não haverá mais suporte.
Caso o faça, vai ter de troca de calibrador.
*** ColorMunki Display and ColorMunki Photo ***
The ColorMunki Display and ColorMunki Photo calibration systems have now been discontinued and has been replaced by the i1Display Studio and i1 Studio systems.
However, your older devices can still be used with the new i1 Studio application. The software gives full compatibility with the latest Macintosh (Catalina OS10.15) and Windows 10 operating systems and has full backwards compatibility with both the ColorMunki Display and Colormunki Photo Hardware.
The New i1 Studio and all the latest updates for the X-Rite photo products software can be obtained from our downloads page below.
